Nova Scotia: Many roads disappear completely when zoomed out a little
Hi, new Scenic user and I'm loving it so far, except...
Here in relatively unpopulated Nova Scotia, a lot of roads, especially good motorcycle roads, are tertiary roads (what the province calls "Routes", vs Trunks and Highways). They're shown as thin grey lines on the map.
The other day I was riding a planned route and came across a washout from the big rainstorms we had recently so I had to edit the map on the fly, and whenever I zoomed out enough to see any towns, I couldn't see any roads anymore. It made it hard to figure out how to get from where I was to where I was going.
Is there (or could there be) a way to set the map's "sensitivity" for hiding roads when you zoom out? I know you can change colors and make road lines thicker, but that doesn't seem to help when Scenic decides not to show the road at all.
Here's screenshots of Google Maps in the area I was in vs Scenic: https://imgur.com/a/RKuvURv
And here's a screen recording showing the sensitivity: https://imgur.com/a/T23JAH3
If you want to test it yourself, see the roads around Middle Musquodoboit, Nova Scotia, Canada.
I know exactly what you mean. This is not just a problem in your region. I am working on a big update and trying to find a way to change the zoom level at which roads are visible. I hope I will find a solution for this, but not sure yet.
Deleted user has reacted to this post.
Deleted user
