No road found between 2 vias
Hi folks!
Had this for the first time.
IOS 18.5 Scenic 4.19 (planned with 4.18).
I know the village Laubach and been there before quite often. Routeplanner is not able to find a direkt route between 12 and 13.  Any hints or suggestion?
German text says:
Couldnt find a route between these vias.
Regards, Mex
Hallo Mex,
bei mir scheint er dort zu gehen.
Beste Grüße aus dem Sauerland
Hallo Karlchen.
Eben nochmal mit Start und Ziel versucht, wie in deinem Beispiel, gleiche Fehlermeldung wie vorher.
Gruß aus dem Westerwald, Mex
Tried short route, Start and Targetflag only. Same error message along the road.
Komisch, dann habe ich keine Idee außer den Routenmodus zu ändern und zu testen,
Ich habe Offline Karten
Were you able to get it working? It calculates for me too similar to Karlchen.
1) Check if your offline maps have an update available (go to offline maps. If an update is available there will be a big yellow bar at the top with an “update all” button.)
2) Try adjusting your routing settings. I tried quite a few (motorcycle) variation but all took the correct route through Laubach.
Not sure what else to check/try.
Thanks for your hints Guido.
I updated all my maps 2 days ago, one after the other. Works better/faster than updating all at once.
Changing settings to bike/short did it. Car/standard didnt work. My preset for planning has been bike/curvy.
Bike/curvy should work without issues because i downloaded the maps of this area.
Here: (small joke) of course its OSM!
Now i know how to handle this, but for newbies this could be frustating.
Side-note: I read all topics and comments, looks like almost no one is willing to take some time and learn how to handle such a great app.
If somethimg is going wrong its the apps‘ guilty. I am driving with Scenic since almost 4 years and still discover new options and abilitys.
Keep up the good work Guido. And all questions will be asked „again“! Thank god, android version is coming 😎
Guys enjoy your weekend. Ride safe, Mex
LaszloK and Karlchen have reacted to this post.
LaszloKKarlchen
Thanks Mex...happy you got it sorted.
Karlchen
