No HFP Sound Output
Quote from ipro on 12.12.2024, 15:26Hi Guido
Today i made a drive with Scenic version 4.07. Unfortunately the sound output via HFP (Hands free Profile) doesn't work. No matter what I set, the announcements always come from the iPhone speaker. A phone call with the cell phone via the HFP profile worked perfectly. Even a phone restart doesn‘t change anything. Is there anything else that needs to be set?
Regards Ingo
Hi Guido
Regards Ingo
Quote from Guido on 12.12.2024, 17:39I’ll have to look into it. No other reports on this so far, but I don’t think HFP is used a lot, so that doesn’t say much.
Quote from Guido on 12.12.2024, 18:25I just tried in my car. I can confirm it’s not working as it should. It does make a connection, but before the connection is made (takes a while), the voice instruction is already over. I was able to get it working by maxing the ‘pre voice delay’ and setting voice speed to the slowest. Then I got the last part of the instruction. But that’s obviously not a good solution.
Will have to look into this how to best resolve it.
Tip: tapping on the navigation arrow repeats the last voice instruction (can be helpful in trying/testing).
Quote from ipro on 13.12.2024, 14:12Hi Guido,
I can confirm that it sometimes works with the delay in the speech output. But unfortunately not reliably and only if the output is delayed for more than a second.
regards Ingo
regards Ingo
