Navigation voice output
Hey Guido good morning,
last weekend inwas riding and notice that the routing voice commands are a lot. Like wich signs you need to follow, names everything on the signs. Or like street names you are about to turn in to.
I remember in the old app you could tun this off. You just hear turn right after 300mtr or so. Is this possible again? I couldn't find it.
Or just a maybe a beep/sound in stead of voice telling you to turn to the right after serveral meters.
Greetings Roy
Hi Roy,
In Scenic 4 you can't make the instructions shorter I'm afraid. You can decrease the number of instructions: Settings > Sound & Voice Instructions > Voice Instruction Frequency.
It's on the feature request list to have a "beep only" mode.
LaszloK
Das gibt es doch schon, oder sehe ich das falsch.
The "alert only" mode only gives alert sounds. For example, when you deviate from your route, or when you are speeding (and audible speeding warnings are turned on). It does not beep when a turn is coming up.
LaszloK and Karlchen have reacted to this post.
LaszloKKarlchen
Hello, I'm Wahyu from Indonesia, I've been using scenic for more than 1 year. Where previously scenic could issue Indonesian, for now it can't. Can you help me. Because I'm happy and satisfied using this scenic. I even entered the 1st rank for Indonesian wilayan. Thank you.
Hi Wahyu,
Very sorry. I had to switch to a new map provider. This new provider does not support Indonesian yet. I’m afraid I can not change that in the short term.
best regards,
