Navigation Screen Issue
Quote from TX7 on 07.02.2023, 20:56Guido, I recently updated my maps. Since then I notice the icons or buttons on the top left of the map screen, (includes map style, show on map and scenic menu) disappear when I click to navigate a route. Leaves a blank rectangle. Not sure if map update is the cause of this or some stupid mistake I am making.
Jon
TX7
Jon
TX7
Quote from Guido on 07.02.2023, 21:27It’s normal that those buttons are not there in navigation mode (to have more space / less destraction for the map and navigation instructions). The ‘map style’ and ‘show on map’ buttons are available through the navigation menu (big button menu) and to go back to the main screen (where menu is accessible) you need to finish the ride by tapping at the ETA bar at the bottom.
The blank rectangle is probably where the turn by turn arrow should go. Once you start riding the first instruction should appear there.
let me know if I misunderstood.
Quote from TX7 on 08.02.2023, 20:55Guido,
Makes sense. I'll confirm the turn by turn instructions pop into that blank spot on my next run. Thanks for your guidance.
Jon
Guido,
Jon
