Navigation Map Orientation
Quote from VstromRider on 28.10.2020, 10:26Is it possible to change the orientation of the map while navigating? I would like the app to always point the my direction to the top of the screen.
Currently, it seems that the app uses North pointing to the top of the screen (or maybe something else) but certainly not my current forward direction. Is it something I can change?
Quote from Guido on 28.10.2020, 19:15Yes. First of all, you have to be in 'navigation mode'. This is the mode you enter when you tap the 'Start Ride' button in the main screen. There you can open the navigation menu (the 'big button' menu). In there is a button to change the map orientation from 'heading up' to 'north up'. It's on heading up by default, but perhaps you changed it accidentally. Hope this helps.
Quote from VstromRider on 29.10.2020, 13:19Thank you. It does work. I have no idea how it was changed since I have been using voice guidance only so far.
