Forum breadcrumbs - You are here:Scenic ForumUsing ScenicNavigation bug
Navigation bug
Today I planned to ride a route from the freshly re-added discover routes feature, but this was sadly barely usable. At some point close to the beginning of the ride the app got stuck at a specific instruction. The map was still showing my correct location and was still panning with me (not rotating in my direction), but it kept showing the same instruction and didn’t mark waypoints as hit. When I pressed the skip waypoint button I got 1 new correct instruction but then kept hanging on that one, that trick worked every time. I just arrived home and noticed the app barely recorded anything of the route, it looks like it stopped recording when I went through a tunnel at the beginning of the ride (this might have also been the point where the issues started, but I’m not sure). Also, when I exited that same tunnel on the way back home I suddenly got another instruction, and it looks like that’s also the point where it marked the end of the route, while it was still another 10 minutes of riding before I got home and finished the ride in the app.
Not sure if this problem was added in the latest version or earlier, I haven’t ridden for a while because of the weather.
Let me know if I can provide you with more information to reproduce this issue.
Kind regards,
Jeffrey
I did change something in the last version. The tunnel has something to do with this. I'll fix asap.
broadbeanprop has reacted to this post.
broadbeanprop
Thank you!
