Multiple Imports at once
Quote from SuperGraupe on 13.03.2026, 04:11In Germany, you can download a list of roads that are closed to motorcycles.
https://www.mintelonline.de/streckensperrungen/
There are more than 100 entries.
It would be nice to import them all at once into a specified folder.
Then you can display this folder on the map and
see whether the road is passable when planning your route.Currently, you have to import each entry manually, which is very time-consuming.
If there are any changes, it is almost impossible to keep up to date.Perhaps there are similar lists for other countries.
Greetings,
Michael
It could look like this.
Greetings,
Michael
Quote from Guido on 13.03.2026, 06:58Hi Michael,
Batch import is not supported at the moment. It’s on the list but will take a while.
Maybe the upcoming feature “road closures & traffic incidents” will help with this. V4.32 with this feature is currently awaiting Apple approval.
Hi Michael,
Quote from SuperGraupe on 13.03.2026, 07:38If it's on the list, it's fine by me.
It’s not an urgent matter either.Greetings,
Michael
Greetings,
Michael
Quote from Mex on 15.03.2026, 00:29Hi Michael,
you can find POIs that show closed roads. Ad them to scenic and you will see closures while planing or riding.
Regards Mex
Hi Michael,
Regards Mex
