Move recorded ride to another route folder?
Quote from HighPeakRider on 31.08.2024, 13:02If I record a ride which I then want to move into a folder where I keep my favourite routes can I do this in the app?
Cant see a way to do it other than to export it then import it into the required folder, seem to get an option to create a new folder but not to move it to routes.
Quote from Guido on 31.08.2024, 13:07This is not possible at the moment. Recorded rides can not be in a routes folder. A routes folder can only contain routes.
It is on the roadmap to add something like "collections" where you can group all routes, rides and locations from a specific trip, but that doesn't exist yet.
Quote from HighPeakRider on 31.08.2024, 13:25Thanks Guido
I ride in a bike night on Thursdays and record these then move them into my bike night folder to track them.
I’ll continue with my export - import process………
Thanks Guido
Quote from mattsz on 01.09.2024, 03:06@highpeakrider - Maybe I'm not totally clear on what it is you're trying to do... but there is an option to turn a recorded ride into a route. Maybe that accomplishes the same thing as your export/import routine, but fewer steps? I don't know... anyway, you probably know about this already...
You can open a recorded ride, scroll down below the map and tap the "route from..." button - accept the choice and the power planner will open with a route based on your recorded ride. From there you can edit it if you wish, then save it in the route folder of your choice...
Of course, then it's a route and not a recorded ride... maybe that's not what you want...
