Mountain pass Symbol
Quote from Sergiobob on 04.06.2025, 22:36Hello, scenic team!
i realised, that in scenic map style configuration , there ist a sign for Mountain pass
bit on the map itself there nowhere this symbol, eeven not on a real pass.
On the osm wiki homepage there is also no symbol for Mountain pass as a cross! Intead as an saddle Symbol!
Hello, scenic team!
Quote from Guido on 04.06.2025, 22:47I’ll take a look
I’ll take a look
Quote from Guido on 05.06.2025, 11:28OK. I figured it out.
First of all, the term "Tiefster Punkt im Tal" (Valley lowest point) is not correct. This term should be changed to "Saddles" (the highest point between two mountains).Now, typically (but not always), a saddle is at the same location as a mountain pass. In fact, in OSM, they are typically the same node. Take the Brenner pass for example (https://www.openstreetmap.org/node/508401093). This has both the tag mountain_pass=yes and natural=saddle. This means that Scenic will show 2 POI icons at the same location. One because it has tag mountain_pass=yes, and one because it has natural=saddle. So, these are drawn on top of each other. At the moment, for custom map styles, the natural=saddle is drawn over the mountain pass, so you don't see the mountain pass icon (a cross in Scenic). If you hide the saddle (Tiefster Punkt im Tal), you will see the cross appear. I'm sticking with the cross, because I don't want there to be any confusion between what's a saddle and what's a mountain pass.
I will fix both issues for the next update:
(1) Rename the "Tiefster Punkt im Tal" (Valley lowest point)
(2) Make sure that mountain_pass is drawn on top of saddle.
Quote from MarWacFfm on 05.03.2026, 03:32Quote from Guido on 05.06.2025, 11:28OK. I figured it out.
(2) Make sure that mountain_pass is drawn on top of saddle.I refer to the following issue: "Now, typically (but not always), a saddle is at the same location as a mountain pass. In fact, in OSM, they are typically the same node." In my opinion the highest point between two mountains ist a saddle, which is deeper than the two peaks. A mountain pass is the highest point on a road leading up to the pass from both directions. That would be the opposite of a saddle. So to my mind it is a principal fault to put both categories (saddle & pass) on the same spot; and that would be the fault of the OpenStreetMap-community, isn't it?
–> I want to add an exception to saddle & pass: If there is a road going over a saddle, which is of course possible, there could be both signs at the same spot.
As I am not very interested in the highest point between two peaks (saddle), therefore I reduced the appearance of that category to a higher zoom level, so it can't interfer with the more important category "pass". For me - problem solved.
