Motive Monkey / Wunderlinq
Quote from Birger_s on 07.05.2023, 10:29I'am one of the very happy prototype user from the Motive Monkey remote control.
Excellent accessories for Scenic.[caption id="attachment_6643" align="alignnone" width="600"]
Mounting the Motive Monkey remote control on a BMW R1200 GS (K25)[/caption]
Now I have 3 feature requests, to include the following items in the menu selection for operation.
1.) Start Siri, it is so much safer and more comfortable.
2.) The possibility of using a specific shortcut / Workflow
3.) Adjustment for upside down operation in the navigation menu, now I have to push the up button to move down.Greets!
Birger
Greets!
Birger
Quote from Guido on 09.05.2023, 07:39Ok. For number 1 & 2, do you mean you would like the ability to link ‘Activate Siri’ or ‘Run a shortcut named xxxxx’ to a MM button action?
The 3rd I believe you are in contact with Bart from MotiveMonkey, right?
Quote from Birger_s on 09.05.2023, 09:44Hi Guido,
yes, for the 3rd issue, I'm in Contact with Bart.
so "only" the first both. And because I activate a shortcut by a Siri command, activate Siri was great, because my Helmet Headset can not activate Siri.
Quote from Guido on 09.05.2023, 10:15Ok. I will see if I can accommodate this. Thanks for the suggestion.
Quote from DoubleB on 30.05.2023, 10:21Hi Guido,
Because I keep having problems with my Wunderlinq system, even after a (free) refurbished device, I’m thinking about purchasing another system.
Is the motivemonkey available for me in Belgium?
Ever thought about cooperating with Bar Buttons, or is this on enemy ground? 🙂
Thanks for your answer in advance
Bart
Bart
Quote from Guido on 30.05.2023, 11:03Hi Bart,
Sorry to hear about the WunderLINQ.
MotiveMonkey is still in prototype state and doesn't work with App Store version of Scenic. You might be able to get a prototype unit. Check out the MM website for more info: https://inventionsforrider.wixsite.com/motive-monkey (Bart, the creator/owner of MotiveMonkey, might be able to help). I can give you access to the Scenic beta version if you can get a unit (the Scenic beta version does work with MM).
Have been in contact with the BarButtons creator. The communication went silent, but I'll try and bring it back to life.
Hi Bart,
Quote from DoubleB on 30.05.2023, 13:55Dag Guido,
Bedankt voor je vlot antwoord. Ik heb intussen Motivemonkey gecontacteerd en zit nu te duimen.
Is de scenic beta nu reeds met de Here kaarten?
Echt benieuwd naar het resultaat. (Zou het heimelijk eigenlijk ook wel eens willen uitproberen. 😉
grtz,
Bart
Dag Guido,
grtz,
Bart
Quote from Guido on 30.05.2023, 15:24De App Store versie werkt ook al met HERE kaarten (vanaf Scenic 3.0)
Echter zal de grote update (nu dus in beta test) het nieuwe HERE kaart framework bevatten.
Quote from johansw on 31.07.2023, 05:45Hi Birger
My brother in law has a 1200 GS as well - where did you get (switched?) power?
Johan, Norway
Hi Birger
Johan, Norway
Quote from Birger_s on 04.08.2023, 11:53
Hej Johan,
i use a adapter (https://www.bmw-gps-interface.com) to power my Phone Cradle. The Phone cradle has a USB-Out and this I use for the Motive Monky Remote.There is a switched USB-Adapter from Wunderlich (https://www.wunderlich.de/shop/de/bmw-r-serie/r-1200-gs-adventure/elektrik-beleuchtung/stecker-steckdosen/wunderlich-usb-doppelsteckdose-45011-000.html) for the BMW-Connector.
Hej Johan,
Quote from Guido on 17.08.2023, 07:46Quote from kn0xster on 17.08.2023, 06:02If you need any more beta testers for Motive Monkey I'd be interested to help there
Do you have a Motive Monkey? If not, I refer to the post above: https://scenic.app/forum/topic/motive-monkey-wunderlinq/#postid-5135
If/once you have a MotiveMonkey, let me know and Ill add you as a Scenic beta tester.
Quote from Birger_s on 17.08.2023, 07:56Hi Guido,
I have a Motive Monkey remote and I use iOS 17 Beta. If you want, I can also test the scenic.
Greetz
Birger
Greetz
Birger
Quote from Guido on 17.08.2023, 08:25Great. Could you send me a direct email (use the 'email me' button at the bottom of the help page here) mentioning your Scenic username please? Then I'll add you as a beta tester.
