Meticulously crafted route grows dead ends when navagating
Quote from Tetsuo on 21.10.2024, 17:44
Crafted a route using in app tools looks great until I push start navigation, then the route grows seemingly random branches that made it difficult to successfully navigate.
Quote from Guido on 21.10.2024, 19:46Hmmm. Very strange. Also the via points are reduced. Would you mind sharing the link to this route with me? (Select route from route list > 3-dots button top right > share link. ) If you’d like to keep it private you can use the email button at the bottom of the help page.
Quote from Guido on 23.10.2024, 12:54Thank you. There is a bug. Scenic should not have allowed you to add more than 148 waypoints (including start and destination). The maximum for the route calculation is 150 waypoints. Scenic needs the 2 reserve to potentially add your current location and the point where/if you left the route (for recalculation).
If the number of waypoints exceeds 150, via points will be removed, which is what happened in your second screenshot.
I'll add this limitation warning in the next update.
For now, if you remove two via points, it should be OK.A general tip / recommendation is to use as few via points as needed.
What I typically do when crafting these kind of routes:
- Place start
- Place end
- Place midway point (more or less)
- And then start adding vias (or stops) about in the middle of each 2 waypoints. If that's not enough (it it's not taking the roads you want) add another, until it does take the roads you want.
- If it's consitently not taking the roads you want, try changing the routing mode (from short to fast, or from fast to short, depending on the result).
- Place start
- Place end
Quote from Dae on 23.10.2024, 13:16I can see how people new to Scenic could inadvertently reach this limit. MyRoute-App recommend adding a via every 2-3km, so someone moving to Scenic could not realise that this isn’t required and get “via happy” 😃
Quote from cgriell on 24.10.2024, 09:21Sorry Guido, in my case (I cannot attach an image, but you'll find it in my today's post) I did not have more than 10-20 waypoints, in my routes I usually have below 20 (I do not count them, but I do not need more).
BTW, I put a name on this issue, Route Warp
