Forum breadcrumbs - You are here:Scenic ForumUsing ScenicMerging routes
Merging routes
I am preparing a tour for next spring. I have already received routes from the organizer. However, some day trips are split. Is it possible to combine these into one day trip? I do not see the option in the Scenic 3 power planner.
Regards,
Geert-Henk
fxstein has reacted to this post.
fxstein
Hi Geert Henk,
Sorry... merging routes is not possible at the moment.
What you could try, if you are a bit tech savvy, it to edit the GPX in a text editor before importing into Scenic. If you open the GPX you received (assuming it's a GPX) in a text editor, you can see the <rte> tags. These tags indicate the start of a route. And the </rte> tag indicated the end of the route. Within these two tags you will find other tags indicating the route points. The trick now is to merge them in the GPX. I.e. remove the </rte> tag from the first part and remove the <rte> tag from the second part. You might need to remove some more items from the second part, like name etc. You'll probably see it if you look at it a bit closer.
Hope this helps.
Alternatively, you could just leave it as is, and save all the routes of the trip in a folder, and in the naming make sure they are alphabetical in order. Scenic now has the ability to change route during the same tracking session. To do this, tap the ETA bar, tap pause, and then tap 'back to start screen'. Then select the second route and tap resume. It will be the same ride, but with the new route.
fxstein, GHJ and phlyter have reacted to this post.
fxsteinGHJphlyter
Oh.. this alternative solution only works well with v3.06 (just released). You might not have it yet. If not... download it manually from the App Store: https://apps.apple.com/app/id1089668246
fxsteinGHJphlyter
