Forum breadcrumbs - You are here:Scenic ForumUsing ScenicMeeting time in-route
Hi, sometimes some other riders likes my rides and they want to join it. Their departure points are somewhere along the route, and I need to tell them that I will be there at my departure time + x hours:minutes. The only way I know of telling them at what time I will be on a point of the route is by creating a new route along the same path, and noting in a piece of paper the elapsed time from the beginning for each meeting point. I imagine for example that adding the elapsed time from the last waypoint in the route editing window (the window which shows "Via n and the three icons", the last one being trash) may not be too difficult. But I ignore if what I am asking for is a New Feature or a functionality which is hidden somewhere.
Hi Carlos,
In Scenic 3 this feature Wilk be added in the route edit screen.
Currently you also see the time to each stop (not via), but only if you are in navigation mode:
- Start the ride
- Tap the bottom bar where you see the ETA
- A panel will slide up
- in that panel is the route timeline. It will tell you the time of arrival at each stop and also the dus ration it takes between stops.
guido
cgriell has reacted to this post.
cgriell
Thanks Guido! we'll wait until version 3, I need to have this information (at least approximate) before actually starting the trip.
I understand. I just offered the other solution as a workaround. You could just start the ride, look at stop eta, and then cancel ride. Just as a workaround for the moment.
