Maybe a bug with Tunnels?
Not sure if this is a bug or not, but at least it doesn’t seem logical. Here’s a region where there is a highway tunnel . In the image below, the Tunnel special road section is off and you only see the red highway.
Here, the Tunnel special road is set to On with a grey color and 100% opacity:
And here, the opacity is turned to 0%. Shouldn’t it be red?
The color you set here replaces the color of the road where there's a tunnel. If you set it to 0% opacity (fully transparent), then you'll only see the outline color of that road. If you set the ouline of a road to 0% opacity, then the transparency of the tunnel will work. Hope that makes sense.
scheeko has reacted to this post.
scheeko
Ah, didn’t realise it was the Outline color. Works!
Thank you.
