Forum breadcrumbs - You are here:Scenic ForumUsing ScenicMap version
Map version
Is there a way in the app to tell what version of HERE maps are being used?
I would like to match my Garmin Nav VI maps to those used with Scenic if possible.... thinking that the conversion of a scenic track to a garmin trip by the nav unit would work best if the maps matched.
That won't be possible. Garmin has its own proprietary maps.
There are bound to be differences because HERE and Garmin (and Google Maps, Open Street Maps, Apple Maps, etc) each use their own way of collecting map data and their own way of processing it. Granted the differences shouldn’t be big (at least in urban areas) because in the end, the actual physical roads are the same of course.
Before HERE maps, Scenic used Open Street Maps. What i found there is no one perfect map provider. OSM is better in some areas where OSM is better in others. I expect Garmin Maps to have its strengths and weaknesses as well.
