Map Style Bug (and Automation)
Hello,
I am experiencing bug with the Dark mode map style. Anytime I switch between applications (or got to the home screen) the map style resets to Normal. So I have to manually set Dark Style again.
Additionally, can an option for automation in map styles be added. Let say at sunset it switched to Dark Mode style and sunrise to Normal Style.
Thank you.
In Settings > Color & Style, you can set the default map styles to use in Dark and Light mode. I think this might be what you are looking for.
Not exactly.
Its somehow tied to the menu as well. I am looking to keep the dark menu but the map layout to auto change or at least remember the selected setting from the "map style" button. The map style resets to the specified on "Color & Style" whenever I exit the app/go to home screen.
I’m sorry, but indeed that’s not possible at the moment. The map style that’s chosen after going to the background etc is dependent on the map style you set in the settings menu and the ‘dark mode’ setting
The map style button is more meant for changing the map style temporarily while, for example, creating a route.
ill add it to the list to make these things independent of each other.
