Map provider issues?
Quote from TheDriver79 on 05.05.2025, 10:28The map in all available layer types (map, satellite, hybrid) is not working properly for me right now.
It looks like the map provider has a connection issue as I can‘t calculate routes and don‘t see roads in higher zoom levels.Is there any link available that shows an API server status?
Hybrid mode just viewing the app and take a closer look to Stuttgart:
Planning mode opening an existing route:
Alex
Alex
Quote from sdk on 05.05.2025, 10:47Hi,
OSM has a Status page: https://wiki.openstreetmap.org/wiki/Platform_Status
For me it's working right now (I'm located near Mannheim). The satellite tiles have been loading slow, but no problem with anything else.
But the little "forbidden" really hints at an API issue... :/
I can also load offline maps right now. With offline maps and the satellite overlay disabled, no networks is needed. Routing works offline then too (except the one that needs kurviger). I would recommend having offline maps downloaded for that reason.
I think route calculation and maps are different services... unlikely that both fail at the same time.
Stefan
Stefan
Quote from TheDriver79 on 05.05.2025, 11:38It works again. So it seems like there was some kind of connection problem.
Thank you for your answer, sdk.
Alex
Alex
