Map Orientation while Following Tracks
Quote from colinleemoto on 01.09.2023, 13:19I recently used Scenic on the Colorado BDR. The tracks are visible on the main map, and the map moves as my location changes on the map.
I was always headed south and the map orientation always had north at the top of the screen. While riding this was a bit disorienting and unintuitive.
It would be fantastic if you could tap the compass icon and have it change orientation modes. For example, by default north is always 'up' but if I tap the compass, then the map would change it's orientation to the direction my phone is pointing relative to north.
Gaia GPS has this feature (I think there are 3 different map orientation modes) and I think this would be valuable to the community who are using this on the BDRs or using the app to following tracks that they import into the app.
Quote from Guido on 01.09.2023, 14:48You can change the map direction through the navigation menu. The setting is remembered for your next ride. Here's a screenshot: https://scenic.app/forum/topic/arrow-always-up-option/#postid-4454
Quote from colinleemoto on 01.09.2023, 15:52The problem is that I can't access the navigation menu when I'm just looking at the map and looking at the tracks.. I have to be navigating in the app for that menu to be available, but I don't want to use navigation when I'm just following tracks...
Is there a way to follow tracks (that would put me in navigation mode) that I'm not aware of?
Quote from colinleemoto on 04.09.2023, 08:11To clarify:
When I'm using Scenic to follow tracks, I'm not entering into any kind of navigation mode. I am just opening the app and allowing it to show the map with me centered on the map. As I ride the app updates to keep me centered on the map, however the map orientation is always 'north is up'.
I'd like to be able to change the map orientation while in this mode. How can I do this?
Thanks.
To clarify:
Thanks.
Quote from Guido on 04.09.2023, 08:20Yes. Even if you didn’t select a route or destination, you can tap the ‘start ride’ button. Then ride recording will start. And only then will you have the possibility to have ‘heading up’.
To put it differently… the start/main screen is not intended for when you are riding. It’s only for planning/preparing. For riding, with or without destination/route, you always have to tap the start ride’ button.
Quote from colinleemoto on 04.09.2023, 08:22Ahhhhh! I did not know that I could start the ride without first selecting a destination. Perfect. That's exactly what I needed. THANK YOU!
