Map issue
Quote from peer234@icloud.com on 02.10.2022, 01:53Good morning,
i have reached explorer extraordinaire status đ.
so I have been using the app a lot and I love it.
But unfortunately I use it less and less lately because I think the base map isnât good. A lot of small roads are missing on the map. This is going to be problematic when you import routes. I can only save it as track because itâs impossible the save the route over ânon existingâ roads.
I know you can reports the map errors, but that is going to be a full time job.I hope there will be future version of scenic with a good map  (I donât if itâs technically possible but I am a fan of openstreet map. )
Greetings
Peter
Good morning,
Greetings
Peter
Quote from Guido on 02.10.2022, 11:54Hi Peter,
Scenic used to have open street maps, but I switched to HERE. It really depends on the region. In some regions HERE is better, while others OSM is better. For example in Mexico, HERE is way better and knows about all small and dirt roads.What region are you in? I can report it directly to HERE as a bug and hopefully they will re-map the region.I know this is probably not the answer you were looking for, but I hope it explains.Best regards,Guido
Hi Peter,
Quote from peer234@icloud.com on 02.10.2022, 16:03Hello Guido,
I drive mainly around in The Netherlands but also in Spain I had issues.
In Mexico I have never been, but sounds interesting.I hope there will be some improvement. The scenic app I really like. Keep it going.
greets
Peter
Hello Guido,
greets
Peter
Quote from johansw on 10.11.2022, 12:04HERE is definitely better in my opinion! The way you can customize colours, size etc is just great as an example.
In Open Maps, there were several roads you could not plan through, and ferries were a big problem.
JSW
JSW
