Forum breadcrumbs - You are here:Scenic ForumUsing ScenicMap direction
Map direction
When a route is being navigated, we have the option of either having travel direction up or north up on the map. When no route is active, I can’t find a way of having travel direction up as it always defaults to north up. I sometimes like to have the map displayed even if I am not following a route, but find the north up view to be a bit confusing sometimes. Is there a way of changing it that I have not found?
Fantastic app by the way! I am in a free trial period at the moment but will definitely be subscribing.
Even while tracking only, the map can be put in "travel direction up". However... this only works in the navigation / tracking screen. In other words... you have to tap "Start Ride". The main screen (that Scenic starts up in) is always north up indeed.
mbird99 has reacted to this post.
mbird99
Perfect! Thank you so much for your reply, Guido. I would like to compliment you on this app,  which I have only downloaded today, but already seems to do everything I want. It is the only navigation app I have found that I can hear the spoken directions at the same volume as my music on my iPhone. Calimoto, MRA, Google maps really do need to learn from you. I will be recommending this to my friends.
Guido, johansw and Marts have reacted to this post.
GuidojohanswMarts
Quote from mbird99 on 18.08.2024, 09:05
If you run an M1 (or later) Mac you can install the iPad version onto it and utilise a large monitor for route planning.
mbird99
Great tip, thanks. I primarily use a PC, but do have access to a MacBook (no idea what processor) so I’ll give it a try.
Marts
