Managing Locations
Quote from PeteRT on 12.11.2020, 13:41I use this https://www.poieditor.com to manage POIs. However it can also be very useful to manage favourites/locations. The online editor allows you to save files in GPX format. These can then be imported into Scenic and if Locations is selected instead of POI then they are saved in Locations. Brilliant. When using the poi editor don't use the '&' symbol when naming places Scenic doesn't like it.
Whilst playing with this it would be nice to able to delete folders even with data inside them. If you have a long list then each item needs to be deleted before the folder can be deleted. Not a big deal. A more useful feature would be able to export the folders as GPX files as a means of backing up your data.
The more I play with this app the more I appreciate the work that has gone into making it.
Thanks Guido.
Peter.
Thanks Guido.
Peter.
Quote from Guido on 13.11.2020, 06:50Thanks Peter. I’ll take a look at the & issue. In Scenic 3 it will be possible to delete folders including content 🙂.
