Location of hotels, restaurants, museums, etc. on the map
Quote from Skdibi on 02.10.2024, 11:29Hello everyone,
How can I display the location of hotels, restaurants, museums, etc. on the map? 😳
Hello everyone,
Quote from Guido on 02.10.2024, 12:31They are currently on the map by default.
The full "show on map" panel and the "may style customzizer" will be added back later. Here's more info: https://scenic.app/scenic-4-faqs/
Quote from mattsz on 02.10.2024, 13:14Quote from Guido on 02.10.2024, 12:31They are currently on the map by default.
What about fuel? I see no map icons for them. Only when I actually search for fuel, I get numbered result with icons on the map.
And... the resulting list of fuel stations include a distance, which is nice... but it appears to be the distance from location seen at the center of the screen. So if I zoom in and move the map to see better detail about where they are, the distance numbers all change. I can't see a scenario where this is more desirable than having the distances indicate how far the fuel stops are from my current location, rather than map center position....
Quote from Guido on 02.10.2024, 13:30Fuel will be added in v4.01(next week)
Distance chaning is a bug... at least if searching during navigation. will check.
While planning, you do want from center screen, as you are probably planning for different location then where you are.
Quote from mattsz on 02.10.2024, 13:46Quote from Guido on 02.10.2024, 13:30Fuel will be added in v4.01(next week)
While planning, you do want from center screen, as you are probably planning for different location then where you are.It appears that the distance changes during navigation - at least while tracking...
Quote from thomas.k on 03.10.2024, 01:56Quote from Guido on 02.10.2024, 12:31The full "show on map" panel and the "may style customzizer" will be added back later.
Thanks for v4, I really like it. I appreciate your work.
I have seen your statement about “show on map panel”. In my region we have a lot of cross-country ski-tracks and ski areas, which are shown on map in highlighting colours. It would be nice if they could be hidden via the panel.
Thomas
Thomas
Quote from Skdibi on 03.10.2024, 03:09Quote from Guido on 02.10.2024, 12:31They are currently on the map by default.
The full "show on map" panel and the "may style customzizer" will be added back later. Here's more info: https://scenic.app/scenic-4-faqs/OK, thank you very much Guido and congratulations on the new version and the continuous work you are doing to improve the app. 👍
