Forum breadcrumbs - You are here:Scenic ForumUsing ScenicLittle gpx export issue
Hi Guido. I just noticed a little problem (I think) during track export using credits instead of a premium account: I noticed a little problem in the track's name during export (but before exporting, during the destination selection) so I hit the back button to correct it and export again. I repeated the procedure and noticed that scenic took me 2 credits even if I exported just once (only 1 file was created). I'm not complaining about the credit, just wanted to tell you this if you think this is an error to fix in a future update.
Thank you again for your excellent work.
Thank Neo. I'm aware of this, but I can't do anything about it. You see the export pane is an iOS built in component. I can 'call' this component, but this component only gives one message back to Scenic. And that's when it disappears. Scenic can't tell why the component disappeared. It can't tell if it disappeared because you canceled it, or because you choose a genuine export options. I figured that in 95% of cases it will be for genuine export option. Sorry for the inconvenience. I know you didn't complain about the credits, but gave you back the credits anyway 😉
Neo9686 has reacted to this post.
Neo9686
Thanks Guido, now I understand the issue, I'll try to keep it in mind in the future. Thanks for the credits too, that's really kind, really great support as always.
