Is it possible that Scenic doesn’t record the ride?
Quote from CuttingIron on 01.06.2024, 17:22Hello,
I made 2 trips these last weeks (about 500-600km) and and using my old iPhone X to record. After the ride, I record the ride but nothing is kept. The worse part is I cannot brag about my fantastic rides ! 😖🤯🥹
Is there any problems with old hardware or something?
keep up the good work, I love the app!
Hello,
Quote from Guido on 01.06.2024, 17:37iPhone X should be fine.
To save the ride you choose the "Finish Ride" and then chose "Save", correct? If so, the rides should show up in your recorded rides. Are they not showing there? Not even on your iPhone X?
Quote from CuttingIron on 02.06.2024, 12:54Hello Guido,
Nope, i thought the first time that I made a mistake and said no. The second time, I clicked on save and went in my house and only later at night when I wanted to show my route that I found that nothing was saved. Is there a way for me to check if there was data recorded?
Thanks again for the reply
Hello Guido,
Quote from Guido on 03.06.2024, 10:59Unfortunately not. Once you click discard or save in the 'finish ride' dialog, the log file is either removed (for discard choice) or first saved into a recorded ride and then removed ('save' choice). What's your Scenic nickname? With that I can check on the server if the ride made it there. I don't expect it did though, seeing as it's not visible on your iPhone X either. To be honest I'm not sure why it wouldn't show there if you chose the 'save' button.
Quote from CuttingIron on 05.06.2024, 16:16Hello, the nickname is etaillefer.
I'll be more careful next time and verify. It's very possible that this is a "code 18" (18 inches from he screen)
Thank you again
Thank you again
