Forum breadcrumbs - You are here:Scenic ForumUsing ScenicIs it me or is it 3D
Haven’t used the app since I discovered this but will browsing the map I went to scroll up and must have caught it as the map view went 3D is this just in planning or does the app now do this, I did see it update the other day?
3D has nog been added yet. It must have been some weird glitch.
Haven’t tried it moving but will tonight.
I implemented a new (patch version) of the map framework in Scenic 4.06, to be able to place the route below road names. The map provider did not tell me that they implemented 3D.
I’ll ask them what the status is, and of course implement if it’s ready for production.
Thanks for pointing my attention to this!
Swiping up/down with two fingers changes the 3D angle
Bei mir leider nicht.
muss ich das während einer Tour machen?
maybe the framework version was updated in 4.07 (happens automatically without notification).  v4.07 is currently in beta test. @gb, are you a beta tester?
Quote from Guido on 03.12.2024, 08:26
thats correct just like the majority of maps on iOS will put a route in and see what happens
Quote from Guido on 03.12.2024, 08:41
Not a beta tester, be happy too if you wanted.
Next stage but not driven
Just to emphasize that I did not test/try this yet myself so I don’t know if this is bug free.
Also ich bin gerade gefahren.
Auf dem iPhone geht es doch auch bei mir.
beide Finger müssen nur nebeneinander und nicht untereinander sein.
Allerdings wird es nicht in CarPlay übernommen und bei jeden Neustart ist es wieder 2D.
Aber top, darauf lässt es sich aufbauen 👍👍👍
Let’s not get carried away here as this is not proper 3D angle in my opinion, it’s still a very steep angle. Will test on the way home from work and see if it stays in the direction of travel. All I did was swipe two fingers so I doubt it would create a bug as such, will report back this evening
Mir gefällt der Winkel besser als bei 3.5.
Nur der Zoom muss noch angepasst werden.
johnsondvr has reacted to this post.
johnsondvr
Zitat aus GB am 03.12.2024, 08:51
Zitat von Guido am 03.12.2024, 08:26
Durch Wischen mit zwei Fingern nach oben/unten ändert sich der 3D-Winkel
das ist richtig, genauso wie bei den meisten Karten auf iOS. Sie geben eine Route ein und schauen, was passiert.
Stimmt, bei Google Maps klappt das auch.
Ok, just put a 20km route home into scenic and dragged the fingers to the lowest and I could and drove home. It stays the same angle all the way ok but you cannot change back to 2d while moving by swiping your fingers again, it just takes you to route over view edit mode. So in reality it’s not right but works just as any other mapping system on iOS but this is not an option created by a scenic update unless Guido tells me otherwise.
Yes... the previosu version had an option to switch to 2D and 3D throught a button in the navigation menu. That button will return. I need to do some testing myself. Am going on a motorcycle trip tomorrow until monday, so will have some good testing time ahead of me.
Dae and GB have reacted to this post.
DaeGB
Looks like the 4.09 update has removed the 3d glitch option
Yes. In planning. But now the ‘perspective’ button is back in the navigation menu during navigation. It’s now like it was in Scenic 3.5.
Quote from Guido on 14.12.2024, 12:33
Hello Guido,
Can you please bring back 3D mode in planning using two fingers swipe up like Google and Apple maps.
If you don’t mind me asking…. why would you need/want 3D mode during planning?
I removed it because (1) I don’t see any benefit on having it during planning, and, more importantly, (2) I like to prevent having ‘hidden’ features... I want to prevent people accidentally putting the map in 3D mode not knowing how to go back to 2D mode.
Quote from Guido on 16.12.2024, 03:25
Hello Guido,
Having 3D mode during planning provides valuable terrain visualization and maintains the same perspective as navigation, making it easier to anticipate what’s ahead without constantly zooming or panning.
While I understand your concern about accidental activation by some people who does not know the two fingers swipe up, a simple toggle with a tooltip in Settings could make this feature intuitive and user-friendly. I can manage with 2D for now, but I truly hope you will reconsider adding this functionality to enhance the planning experience.
Best Regards
johnsondvr
How detailed is the terrain, I live in a totally flat area so it all looks the same? Is it like basecamp in 3d?
Interesting topic, this 3D one. I've noticed that sometimes the map will display in 3D mode and other times it is in 2D.
Next time I go for a ride I'll note when each mode is displayed (planned route, tracking, etc.).
3D does present better, I reckon, especially on smaller screens such as the Chigee AIO-5 Lite.
