Iphone settings - localisation
Hi Guido!
I am (up to now) on the free plan.
When using Scenic just for tracking, do I have to have the security settings on IOS to ALWAYS or would
it be enough with "when using the app"
The reason is, what will happen, when I use on my Iphone other apps while tracking, will the tracking stop?
Thanks, Uwe
I recommend always. It only has advantages. Scenic won’t use your location when you are not tracking. Here’s more info why always is better: https://scenic.app/help/not-tracking-entire-ride-pause-resume-tracking/
uwe59 has reacted to this post.
uwe59
Thanks Guido!
That's exactly what I need to know!
BTW, this customer support leads me now to the decision, to go for Premium...
Just subscribed!
Bedankt!
Uwe
Guido and mattsz have reacted to this post.
Guidomattsz
Just subscribed!
Bedankt!
Uwe
You won't regret it.  Guido's commitment to supporting his app and its users is, quite frankly, astonishing!  He deserves our support...
Guido, Old Man Emu and Patrick have reacted to this post.
GuidoOld Man EmuPatrick
Odd... I checked my "regular" iPhone to see if the location setting was set to "always"... it wasn't, so I changed it.
Then I went to my no-sim "navigation-only" phone (same model and OS as my "regular" phone)... and I find that Scenic doesn't exist at all in the Settings' list of apps.  So I can't check it, or change it...
Maybe because I don't have a activated sim card?  I don't know... two other mapping apps are listed there...
I have seen this happening myself too. I don’t know what is causing this to be honest. It has to be some kind of bug in iOS. I found that sometimes it helps removing Scenic and redownloading from the App Store. I say sometimes because it seems to be a bit random. Sorry I can’t be of more help in this. Same device, same OS, same Scenic version (I assume), different result…
Hmm... I tried this, no change... except I have to re-download all my offline maps, and all my in-app settings I've changed and customized are gone.  Disappointing...
Is there a way to transfer app settings and map styles?  These aren't remembered between devices when I log in?
Map styles should sync automatically. If not try tapping the little sync button top left of the map styles screen.
Setting a don’t sync indeed. Partially because some would want different settings on one device than another.
Quote from Guido on 16.08.2023, 19:56
Guido, we're posting at the same time!
I discovered map styles do sync automatically.  Agreed that some might want different devices to have different settings.  Too bad it couldn't be a user option - click a button and sync all settings... then make changes if you like.  But I can see problems... with different settings on different devices, how would you know which one to sync to?
It only took me a couple of minutes to get my nav phone settings back where I want them...
