Importing GPX from iPhone “Files” app
I tried to import a gpx file from my phone to scenic app by following in app instructions and I don’t have an option to send it to the app. Scenic app is missing from the list. Tried to press on square with up arrow option inside of “files” and “drop box” apps. How can I import files from my iPhone into scenic app?
In the panel that appears you will get a list of apps that (theoretically) support the GPX file format. If Scenic is not directly in the list, swipe that app row all the way to the right and tap the "more" button. Scenic should appear. If it doesn't, try to fully shut down and restart your phone. (When apps are run the first time, iOS should register which file types they support. Sometimes that doesn't happen and a phone restart is required. )
Restarting phone didn’t work. Scenic app is not in “more” list.
Try removing Scenic from your iPhone and then reinstall.
This is an iOS issue. Upon install / first run of Scenic, iOS should read and register what file formats Scenic supports (so it knows to show Scenic for GPX files in the panel). I've noticed in the past that this sporadically just doesn't work. I can't do anything about that. It's just a matter of trying again and make sure that Scenic.
I'm assuming you are sure this is a GPX file with the correct extension and file format.
Uninstalled/reinstalled/restarted multiple times. Still not an option.
uploaded file from phone to web and downloaded via app, now route is gone, just POIs 🙁
Any suggestions?
Can you send me the file you are trying to import? (Use the ‘email’ button at the bottom of the help page).
(Sorry… I posted this request before but somehow it didn’t go through / maybe forgot to click submit).
