Forum breadcrumbs - You are here:Scenic ForumUsing ScenicImporting from curviger
I was planning a trip with curviger, when I exported the route end imported in scenic I have not clear which one of the two options to use, the first one do not correspond with my planning, the second one more accurate, but with small loops near some points.
any advice?
thank you
Max
Hi Max,
Have a look at this forum post: https://scenic.app/forum/topic/route-is-different-when-importing-from-kurviger/#postid-6706
If you have questions after that, please let me know.
I’ve tried but when I import the track from curviger via scenic as indicated it makes a different route and from 5 h and 8 minutes becomes 9 h and over
Can you send the Kurviger URL to me? If you don't feel confortable posting here, you can send it to me via email, using the email button at the bottom of scenic.app/help
1000 Miglia tappa 4 - Nocera Umbra Anguillara | Kurviger
I see there are some differences indeed. Some of them can be corrected by placing additional via points:
If you like to know more about why this is happening and how to do the corrections, have a look at the link that the other forum topic referred to.
Unfortunately, this one below can not be corrected. Scenic seems to think you can not go on this road. This can be because of seasonal closures and/or because Scenic does not know the road exists. There are some workaround for this too, provided in the link that the other forum topic refers to.
If you need any more help, please let me know.
Thank you Guido,
in the last case, if I import the gpx file the route is correct, but whem I'll be there scenic will give me the right infos following the Kurviger map or will recalculate?
Do you know the answer?
Scenic will always recalculate. You could do "save blue line as track". Then it will save the blue line exactly. But then you will not get turn by turn instructions. Only "follow the line" instructions.
Ok! Hope will find a way!
thank you
Max
