Importes GPX file can Not be saved
Hi folks I’m having an issue that I’m not able to solve.
I have received a file (generated in base camp) which I was able to import to Scenic. For some odd reason I’m not able to save it  I have also tried it with other files with the same result  I even tried to delete most of the points (28 remaining) but still no change. I can see the save button, but it’s grey and I can’t save it.  Has somebody an idea, how to get the file in the system?Original file with stops
I don't see a start flag. Try placing a start flag. Not sure why it's not there though. On import it should show.
converted has reacted to this post.
converted
Quote from Guido on 22.09.2024, 08:25
that's embarrassing! You are absolutely correct! That was the problem. So to bother you for that!
