Imported Route from Basecamp won’t go into tunnel
Quote from KM on 03.08.2025, 07:03I’m trying to import a Basecamp Route into Scenic but rather than go into a tunnel and follow the stops, it goes another way seemingly against the traffic over a bridge.
Any ideas
Kevin
Any ideas
Kevin
Quote from DRTBYK on 03.08.2025, 12:04You might also have better results if you save your BaseCamp Route as a Track and export that Track to GPX. Scenic does a pretty good job of Importing and converting Tracks and Import Edit is relatively easy if corrections are needed.
Looking at Satellite imagery from a couple of sources, it doesn't look like that other (tunnel?) bridge is even completed yet. None of the current OSM maps will even route that path.
Quote from Guido on 05.08.2025, 04:58Scenic currently uses the type element inside the rtept. If that has "via" as value it will create a via. If that's anything else than via or missing, it will become a stop.
<rte>
<rtept>
<type>via</type>
<rte>
<rtept>
<type>via</type>
