Forum breadcrumbs - You are here:Scenic ForumUsing Scenicimport own POI file
import own POI file
How can i import my own POI file ?
I tried to follow the youtube video but i dont understand passerknackker.
this should be an easy button right ?=
Passknacker is just an example website where you can download POIs as waypoints in a GPX files.
You can add a POI group manually, by going to Locations and tapping heblittle + button.
Mostly though this is used by importing POIs. To import POIs you need a GPX file with waypoints in them. The second part of the tutorial video part does not change for that.
Also have a look at this forum post: https://scenic.app/forum/topic/locations-vs-custom-pois/
I dont understand.
I tried to register with passknacker but they ask too many personal questions.
Thats a no go for me.
I tried google on convert POI to GPX as i understand thats the way to go.
But could not find anything.
So i am still lost on how to get all the Harley dealers POI into Scenic.
Are you interested in HD dealerships in a specific country? I know a user who has a file with all Germany HD dealers. I can ask him to send it or post it here.
i have the updated world database harley dealers.
thats even better 😉
Where / in what software / website do you have that? Does that software / website support exporting to GPX or KML file? If so, you're have way there. Then you don't need passknacker, google maps, etc. Just follow the video from where the "webapp" appears and drag the exported file in the box.
Quote from Guido on 22.02.2024, 08:52
Hallo zusammen,
gerne stelle ich die Datei zur Verfügung. Es sind 305 Harley Dealer aus Europa drin.
Hinter den kleinen Zahlen verbirgen sich weitere HD Dealer.
Nur leider kann ich die Datei hier nicht hochladen. Ich bekomme folgende Fehlermeldung.
Ich schicke Giudo die Datei.
Ich hätte Intersse an die Datei aus der ganzen Welt
Beste Grüße
Karlchen
you can download it here:
https://serviceinfo.harley-davidson.com/sip/content/document/view?id=1868379307175721342
Karlchen
So, the file on the Harley-davidson website is a specific format for their BOOM system. It's not supported by Scenic.
Here's the file from Karlchen, with all the dealers in Germany: https://drive.google.com/file/d/1NCyEm8ma4mo43hPB8HU-njHr2RrQRE9U/view?usp=sharing
To import this file:
- Go to the Scenic WebApp (scenic.app/webapp)
- Select the GPS file option by drag/drop and drag this file into the field
- Now go to the import queue in Scenic on your mobile phone.
- Select all waypoints and tap "Import"
- Select the import as POI group
- Then you must activate this POI group as a "layer" by tapping the layer button on the main screen (3. Button from top left).
Here is the piece of the tutorial video that shows this. It still shows the old version of Scenic, but the process is the same.
Karlchen
Hallo Guido,
nicht nur Deutschland. Ganz Europa.
Hallo Robert,
viel Spaß mit der Datei.
Beste Grüße
Karlchen
awesome !
all dealers in scenic
vielen dank !
Karlchen
Ich hab noch,
Bergpässe mit und ohne Maut
Höhenstrassen
Tourenfahrer Hotels
Polo, Louis…..
Die Datei lässt sich hier hochladen, wenn man sie in ein ZIP packt.
Karlchen
