Import of routes
Quote from ArneKoeln on 09.02.2025, 08:40
Hi there! In the past I had and right now I have issues when trying to import routes. The problem appeared first when I tried to import a route, that was sent by me via WhatsApp, from another scenic user. Today I wanted to import routes from the TET website and the same problem came up. After I push the usual share-button (at WhatsApp or Safari), where the Scenic app comes up, the Scenic app leads me to the site which you see at the screenshot (sorry it’s German language). From there on I have no opportunity to import the route. Then I try the same procedure again and again. It is randomly if I can import the route or not, when trying to import a route several times.
Quote from Guido on 10.02.2025, 10:31I've had more reports and I'm looking into it.
As a workaround, you could import the GPX files using the webapp ( https://scenicapp.space/webapp.php ) Drop the files in the box on the webapp, and then go to the "import queue" on your iPhone.Sorry about this. Will have this fixed asap.
Quote from windingroad38 on 28.08.2025, 14:16Same issue here.
Got a link and tapped „add to scenic“
After 2nd try I get this
And in Scenic it looks like this:
saying: „no routes in import queue“. So where is the route now?
Export the route as gpx from the link and then importing this file (open in scenic) works
Scenic v4.23
Same issue here.
Scenic v4.23
Quote from Guido on 28.08.2025, 14:26If you got a link to a ROUTE the route will be placed directly in your “My Routes”. No need to go to import queue. Go to “My Routes” through the side menu, do a “pull to refresh”. Then the route should be there somewhere. If you can’t find it immediately, try searching for its name (the name is the same as the name displayed in the link).
Quote from windingroad38 on 28.08.2025, 15:10Oh, yes. My fault. I thought I had to go the import way in any case. Thanks
