Import Not Workimng
Quote from jackm on 01.08.2024, 19:24I am trying to import a GPX file to the Scenic App on my iPhone. The file is in the Files app on the phone. When I share the file it allows me to select the Senic app and when I select it, it just opens the app. File is never imported. All software on phone and Scenic app are the latested versions.
It would be a nice addition to navigate to the file rather than the share procedure.
Thanks,
Jack
Thanks,
Jack
Quote from Guido on 01.08.2024, 19:28I had more reports about this. Seems to be specific to the files app. It works when you first open Scenic and then go to files app to “open in” Scenic.
It works regardless of Scenic is open from other apps like mail and WhatsApp.
Will look into this for the next update.
Quote from jackm on 01.08.2024, 19:43OK. I tried it from mail and OneDrive, the Scenic app does not even show up when I share.
Hopefully you can resolve it.
Thanks again,
Jack
Thanks again,
Jack
Quote from Guido on 01.08.2024, 21:36Have you checked the “more” button?
Have you tried with the files app when Scenic is already started?
Quote from Guido on 01.08.2024, 21:37Another option is to import through the scenic webapp: https://scenicapp.space/webapp.php
And the go to import queue to finish the import.
Quote from Karlchen on 02.08.2024, 00:57Wenn ich eine GPX-Datei in Dateien mit Scenic teile, kann ich sie importieren. Dann geht die Route im Powerplaner auf und ich kann die speichern und bearbeiten. Vorausgesetzt Scenic war geöffnet.
Beste Grüße
Beste Grüße
Quote from jackm on 02.08.2024, 10:18Seem to work from Files app if I have Scenic open first.
Webapp works fine on Mac.
Webapp does not work on iPhone. I can get to the select files box from Webapp and navigate to the Files app, but it does not allow me to select files.
You cannot drag files on iPhone.
Jack
Jack
