Guido on 16.05.2022, 03:02
The menu from the screenshot is accessible while you are navigating. So, after you tapped the 'Register Ride' / 'Start Navigation' button. Then you'll go to 'navigation mode'. Only in 'navigation mode' will the map be able to go heading up. So, you should always use this button if you start to ride really. Even if no need for navigation.
Once in navigation mode you can access this menu by tapping the button bottom right of the screen.
