How to go back the same way
After I complete a route, is there a way to tell scenic to head back the same way?
If I understand you correctly... the answer is yes!
Navigate to the "Routes" menu and tap the route in question to select it.  Scroll down and select "Edit Points"... or "Duplicate" if you want to create a new opposite-direction route rather than change the original route.  Either choice will open the Power Planner.
Down in the bottom row of buttons at the bottom of the screen, you'll find a "Reverse" button - tap it and your route should be reversed, including start and finish points, with via points re-ordered to match...
Awesome! Thanks very much.
mattsz has reacted to this post.
mattsz
At least if the route has been planned in power planner and saved, there is a menu choice at the bottom of the screen to turn the route the other way around.
Problem: when I go to route, I have power planned and saved, I can’t get to anything at the bottom;there is nothing there. All I get is the route I planned and I can’t edit it. Do you know what I might be doing wrong?
I imaginge you are on iPad or Mac? Check out this post: https://scenic.app/forum/topic/planning-and-using-different-type-of-route-settings/#postid-7066
It won’t paste.😕
You don't have to paste. The screenshot is just to show how to get to the buttons below the map. If you grab on the map, it will move the map. If you grab in the circled area it will scroll down below the map, making the buttons visible. One of them is the "edit points" button, and there's a "duplicate' button. Those will bring you to the power planner (the duplicate button first makes a duplicate of the route).
Old Man Emu
Got it! Thanks .
