How to get a route from kurviger to scenic
Quote from Franz Lang on 04.07.2021, 15:28Hi Guido,
i already had 2 posts about that and i thought i had the solution, but something changed again.
I aggree not to use "send to scenic" because kurviger changed some month ago, i export to GPX and import the GPX into Scenic. Now kurviger changed again and scenic had some updates.Up to now the best way ist normaly to export 25 waypoint and that works fine and scenic imports and made a route out of the waypoints. But when i import this now i am asked by scenic if i want to import the waypoint, if i do that i get the whole list of waypoints into scenic but nothing else happened and no route is created. When i export the route in kurviger without waypoints, then the import works fine and i get a route created. So what did changed?
PS: it is summer, when can we expect the new version 3 ;.)
Quote from Guido on 04.07.2021, 15:44Hi Franz,
Nothing changed on Scenic side recently. I caught up with the changes that’s Kurviger made a few versions back. So, you should be able to use the ‘send to Scenic’ button now without problems.
Perhaps Kurviger changed something in their GPX export, but I can assure you that since about 2 months ago nothing has changed on Scenic side.
Hi Franz,
Quote from Franz Lang on 05.07.2021, 14:14Hi Guido,
after i find out where "send to scenic" is, (they changed the place) I used it and it works fine.
PS: Scenic V3 ?
PS: Scenic V3 ?
Quote from Guido on 05.07.2021, 14:17Scenic 3: See latest newsletter. If not subscribed... you can do so here in the sidebar (or down below if you are on mobile).
