How to delete routes made public?
Quote from ryder_hook on 27.08.2024, 11:20The subject already says it, I have set a tour to public that I would like to delete. How can I do this?
Wishes
ryder
Wishes
ryder
Quote from Guido on 27.08.2024, 12:16Hi @ryder_hook,
The "My Public Routes" and "Route I Rated" folders are "smart" folders. They contain the routes you made public and the routes you rated respectively. You can't add or remove routes from these folders manually. To remove route form the "My Public Routes" folder, select the route from the list, and then make it private again.
Watch out though. If this route is not in any of your normal folders it will be gone. If you want to keep the route for yourself, make sure its also in one of your normal folders before making it private.
Hi @ryder_hook,
