How to add via points to an imported Route
I have used Scenic alongside my Nav 6.  If I import routes as GPX from Nav 6 to Scenic they are sometimes slightly different as I presume that calculation algorithm is different.
How can I add a via point or stop to shape a route in Scenic ?  I've tried using the via# or stop# buttons but it puts the points out of order.  Does the button need a long press or is there another button I am missing?
Kevin
Aim single press means Scenic chooses automatically where the via goes. A long press lets you choose between which bias it goes.
Part of the issue causing the problem is a wooden suspension bridge that’s apparently been closed since 2019. Open Maps knows but Garmin don’t and send me over it, hence the need to alter the route. I was trying to force Scenic over the bridge until I googled the location. No wonder I was struggling.
Scenic is a great app.
