How to add gas stations to my existing route?
Quote from BlasterMaster on 28.05.2023, 13:01I created my ride in a third-party software and brought it over to Scenic and now I have it on my iPhone. My question is, I would like to add gas stations to it. Can I do this from the Phone app?
Quote from Mex on 28.05.2023, 23:47Hi BlasterMaster,
you can add gasstations like anything else.
While you navigate go to the lower right big button.
Select overview.
Select search, second from the right.First choice are gasstations.
Select the one you prefer, may let them show on your map, and add it to your route.
Scenic will ask you which via you want to be behind the gasstation.
Add it to your route as via or as a stop.
Hope that helps/explains.
Regards Mex
Hi BlasterMaster,
Select overview.
Regards Mex
