Guido on 03.09.2024, 13:44
The cache is 500MB.
If part of the map can't be found in the cache (or in offline maps on your device), Scenic connects to download a part of the map, throwing away the oldest data in the cache to make room for the new data.
For route (re-) calculations, Scenic always tries offline first. If that results in an error because of missing map data, and you have a connection, it will connect to the server to calculate online.
The cache is 500MB.
