Forum breadcrumbs - You are here:Scenic ForumUsing ScenicHelp with tracks
Help with tracks
Am I doing something wrong, I send/import a gpx file to scenic and it imports ok and I save the blue line as a track but I can’t seem to separate the track from the route scenic creates? These are off road tracks that scenic can’t route so I only need to see the track not the route.
After saving blue line as track, if you then clear the route, only the track should be saved. Then, when you select the track from your route list, you should only see the track. Not sure if I understand your comment correctly?
That’s what I thought would happen but it deletes both. The blue line is dotted, does that signify anything.
Yes... when you clear the route it clears both. But, if you "save blue line as track" before clearing, it will save the blue dotted line only.
