Forum breadcrumbs - You are here:Scenic ForumUsing ScenicHelp with importing
Help with importing
Hi
hope you can help me on this and it’s something simple I’ve missed. Downloaded all of the TET Italy for a trip next year. Go to import but how do I import just the track, I can see the track in blue but it’s different to scenics route? I just want to save the tracks to save any rerouting issues.
If you tap the floppy disk button, you should get a menu. One of the options is the menu should say "save blue line as track".
Don’t seem to get that option Guido?
It gives me save changes or save as new route?
Think I’ve sussed it, when I’ve downloaded it I went to download the next section without clearing the downloaded part so it tried to update
Hmmm. OK. I'll have a look at that, because that would be a bug. As long as you select the track (not the route) from the GPX, the option to 'save blue line as track' should appear. Even if you select another track when one is still on the screen, the one on the screen will be replaced. I'll investigate.
