gpx-track import problems
Quote from karinmoto on 18.02.2024, 05:36Hi there
I've been looking around, but I couldn't find a solution to my specific problem.
I'm planning to go to Morocco and I wanted to import tracks from "pistenkuh.de", a guidebook to 4x4-tours. Of the 54 gpx-tracks, I could import 37, with 17 tracks Scenic-App told me: "Route konnte nicht berechnet werden. could not match destination". Wanting then to save it as "track" (button:(Original (blaue Punktlinie) als Track speichern), Scenic-App closes down. I tried it downloading the offline-map for Morocco first, but it doesn't help.
Funny tough, the other 37 tracks are mostly not leading along known paths/roads on the map as well, however I could save them as "track". Importing Tracks from the same provider (pistenkuh) in MonteNegro/Albania into Scenic-app earlier version (sometime in 2022) were no problem.
Don't know if the problem lies within the app or the gpx-data of the provider. Anyone had the same problem and found a way to resolve it?
Thanx
Karinmoto
Mobile Device: iphone SE 2020 iOS16.6.1
Hi there
Thanx
Karinmoto
Quote from Guido on 18.02.2024, 07:52You should always be able so save as a track, because that doesn’t rely on map data or knowing roads. So this is most likely a bug. I’ll look into it. Would you mind sending me one of the GPX files that made the app crash? You can use the “email me” button at the bottom of the help page.
Quote from karinmoto on 05.03.2024, 02:30Thanks Guido for reacting to my problem so fast!
To the community: It was a bug in the App that created this problem. I'm glad: for once the nut was not between screen and keyboard. I downloaded the rest of the tracks now and it worked fine.
CU Karinmoto
CU Karinmoto
Quote from karinmoto on 22.02.2025, 04:43Hello Guido
I'm planning to go to Morocco again and I convinced my companion to download Scenic to have the same device and tracks as I do. However, there are some (5) tracks that he cannot download: "Calculation Error of Route. Unknown: leg-shape-index not set for intermediate location" it says. Could this be a bug again?
Thanks for looking into this problem..
Karin
Hello Guido
Karin
Quote from Guido on 22.02.2025, 07:53Maybe. Could you send me one of the GPX files? (use the email button at the bottom of the help page). And, you are trying to save as track, correct? Not as route.
