Generate Trip in Power Planer with direct routing
may it is possible but I don't found it.
Today it was a sunny day and I had a coffee at my favorite meeting point for biker.
I want to ride a little bit longer and started the power-planer to place some Vias for a short route.
What is miss is to start the route directly from the power-planer. Just without to save it.
It's only for this day and has not to be archived.
Now I have to save the route as "today".
Go back to my routes, search and load it.
Start the route.
At the end I have to go back to my routes and delete the route.
Greetings,
Michael
I sometimes have rhe same situation. I then first select my End point and then long-press points I want to pass, choosing it as Via og Stop point. You can make several points this way, Scenic tells you how to do it. When finished, Start Navigation
Thanks for the responce.
Just tried it and it works.
Have to held it in mind :-).
Greetings,
Michael
Great tip!!! Thx
