Function to add additional points in ride mode not working
Maybe I don't understand something in interface but following scenario is not working:
Open scenic (ios version);
Search destination;
Start ride;
(track is generated)
Double tap to enter in edit mode;
Search for fuel;
Map is pointing on gas station;
Press select in dialog.
And nothing happens. Track does not rebuilded.
What i'm doing wrong ?
Thanks.
I'm find solution: I should click on my current location.
It's not intuitive when you have only destination.
Be cool if it be fixed in future release to make it more intuitive.
Ok. I understand what you mean. It’s asking to tomato the marker before the new stop (fuel station in your case). If you only have a destination this might not seem intuitive.
Hiwever there are also scenarios where you maybe want to put an extra stop AFTER your reach the current destination. Scenic does not know if touwbanen it before or after the destination. That is why it is asking at the moment.
I could automate it, instructing Scenic to make an educated guess, but it could guess wrong.
Ill give it some more thought on Joann can make this better/more intuitive.
Deleted user has reacted to this post.
Deleted user
Hi, Guido
Maybe extending "select dialogue" in navigation mode with items like "Add as next via point" and "choose after point" - is adequate solution.
Thanks.
