Feedback v4.13
Quote from Lo100469 on 02.03.2025, 12:25Hi Guido,
the last 2 trips did show a significant improvement, i used Scenic for a 950kms trip (wireless CarPlay) and for a 250kms trip (wired careplay).
All went well, the display moved to dark in tunnels and went back to light automatically. Also the zoom seems to work better.
The only issue i had it when i stopped for fuel and the petrol station was on the other side of the road, so i made a U turn and then a second U turn to continue the trip. I was on the purple line but Scenic did want to send me back to the starting point. Also ETA is overestimated but that is not new.
I also had updates for the maps but i had to check that, i have not seen any message that new maps were available to download.
Overall it works well for me, i hope to have the speed camera soon.
thanks Guido,
Regards,
Laurent
thanks Guido,
Regards,
Laurent
Quote from Cornworld on 03.03.2025, 12:48Hey Guido
first of all, the app keeps getting better by the update. Good job, really enjoy using it
I have two issues with the current version while using CarPlay.
Switching from dark to light mode works nicely when the app is in fullscreen. When I use splitscreen it somehow goes back to dark mode. As soon as I switch back it goes back to light when riding in daylight.
I also have an issue that the app wants to send me back towards the starting point even when I chose not to drive towards the start point. While one the route, even when passing the first waypoint it tried to send me back. Had a few times when I had to manually delete the startpoint in order to get the route to show correctly.
I hope this makes sense. If you need more date or tests from my side to pinpoint the issue let me know.
greets Corné.
Hey Guido
greets Corné.
Quote from Guido on 03.03.2025, 13:01Yes. That makes sense. I'll look into it.
Regarding the dark/light mode. What's correct? The split screen or the full screen?When connected to CarPlay, Scenic uses your CarPlay appearance settings. The appearance settings on your iPhone (the general settings as well as the settings in Scenic) are ignored. If CarPlay is in dark mode, Scenic will be in dark mode.You can force CarPlay to always be in dark mode (regardless of your CarPlay system settings). To do that, go to the CarPlay settings (on your carplay system).
Quote from Cornworld on 03.03.2025, 13:12The light mode in fullscreen was correct. Dark mode was incorrect, phone was on daylight mode as was CarPlay.
