Export Scenic route contains no waypoints in Rever
So I exported a Scenic route to a friend who uses Rever.  While the overall route imports fine into Rever, none of the way points show up on the Rever website.  Any remedy to this?  Thanks!
I'm afraid you'd have to ask Rever about that. The GPX that Scenic exports contains 2 routes and one track. One of the routes contains information that distinguishes stops from via points (Scenic uses the Garmin extension for that). My guess is that Rever doesn't handle this in their import, or takes the track for the import.
If it helps:
Here's a very simple route in Scenic with one via point and one stop: https://scenicapp.space/route/wNFAMWOg
And this is the GPX of this route as Scenic exports it: https://www.icloud.com/iclouddrive/0DcmXXkP9Q2UeJLBJeD0OF1qg#cosaco---mompani
fxstein has reacted to this post.
fxstein
I noticed that Rever interpreted a stop as a waypoint so I changed all waypoints to stops in Scenic and my friend said that imported perfectly.  So that's the workaround for now.
