Exit numbers on motorways or ring
Quote from tcherpeti on 18.07.2025, 01:08Hello, I usually not drive on motorways -exept- rare times for contourning a city.
It would be helpull that we have on the screen the exit number, to keep it in mind while roading on the ring road , not being disturb by the screen in huge traffic to catch the good one exit.
I search in the customized map to make it appears but not found it. How can I get thoses exit numbers ?
èxample here : for avoiding the city of Toul, riding south, first exit after water, not the second one.
Here below the "Michelin" map : exit 13 is clearly showned
The same location in the app : no numbers appears, at different zoom view either.
thanks and good hollidays everybody
Quote from MjK on 18.07.2025, 12:48Hi @tcherpeti,
my experience is those exit numbers are shown during navigation like in this example on my way towards Munich:
but as you call out, they are not part on the map during planning, even so they are contained in the OSM map, maybe Guido @guidomm can make them visible as part of the styles.
Cheers, Markus
Hi @tcherpeti,
Cheers, Markus
Quote from tcherpeti on 18.07.2025, 13:58thank you Markus for your explication .
yes as you say “but as you call out, they are not part on the map during planning, even so they are contained in the OSM map, maybe Guido @guidomm can make them visible as part of the styles.” , 👍
