Error Messages
Quote from axel on 23.04.2021, 05:03Hi,
Last week, I created a route in scenic on my iphone but when I tried to use it, scenic said something like "route can not be calculated". It was roughly a 2h+ route with below 10 waypoints and I did remember most of it, so it was a good ride, without scenic.
Back at home, I testet the route in kurviger.de (gpx ex- and import) with no problems at all. Now, on my phone in scenic, I moved some waypoints and tried to calculate the route again. Now it tells me: "No route found between points." Again, kurviger.de is able to import the gpx route.Has anyone else had this error?
Would it be possible, to be more specific about what causes the error in scenic? Something like "Problem between waypoint x and y"? And maybe for people like me a "this route has problems" when saving a route.
best regards,
axel
best regards,
axel
Quote from Guido on 23.04.2021, 07:00Hi Axel,
Thats strange. Would you mind sharing the link to the route here? You can use the ‘Share’ button above the map preview after selecting the route from your route list.
With the link I can have a detailed look.
Hi Axel,
Quote from Guido on 28.04.2021, 13:55Hi Axel,
The route as it is in the link calculates fine here on my side. I guess the changes you tried to make in waypoints are not reflected in this route, so I can't reproduce the error you got, since I don't know where you tried to move what waypoint.
Usually the "No route found between points"-error occurs when one of the via points is not on a road. I.e. when one of the via points is not reachable by a road (a road known to Scenic). Unfortunately the 3rd party routing engine does not give any further information as to what via point is causing the problem so Scenic can't be more specific on that.
Know this is probably not the answer you were looking for, but I hope it at least explains. Let me know if you have any further questions.
Hi Axel,
